...... other than getting it X-rayed?
I'm trying my best to check over my race chassis for cracks etc. Its painted black metallic which doesn't lend itself well to inspection!
(wish it was grey!)
I'm using as much natural light and florescent etc but I'm still not convinced.
Does the collective have an easy (foolproof) way of inspecting a used chassis?
Thanks in advance!
The foolproof way of testing for cracks is to pressurize the chassis - my drag bike frames were used as the air tank for the air shift , so any cracks
meant no racing till it was fixed (not that I ever had such a failure , but you get the idea)
The downside to this is it has to be planned for at the build - all connecting tubes have to be drilled at the joint , and every joint has to be
perfect.........
Dye Penetrant would show up cracks.
It's a simple aerosol system.
Paul G
Dye pentrant and visual inspection is the only viable way --- you have to wire brush the paint off at the joints.
Magnetic particle works as well.
Paul G
As Paul said, MPI is probably easiest, but needs paint to be removed first. Would probably be easiest way on the welds.
Tom
Thanks for all the replies!
I'm not in a position to fully strip the chassis and then remove paint from welds so I guess its a good visual check this year, then full strip
down next year.
Claire - love the frame pressurisation method!
pressurised frame is the same reason I dont mind banded steel wheels, 100% Non destructive testing cycle!
I'm not in a position to fully strip the chassis and then remove paint from welds so I guess its a good visual check this year, then full strip down next year.
When I used to make coded stuff the lifting lugs were always MPI'd. (You can't Xray a fillet)
The inspector would spray the weld area with quick drying white paint and allow to dry, then spray with the particle liquid.
The iron power magnetic field lines were easier to see on the white paint.
What you need is a white chassis.
Happy New Year
Paul G
MPI is the easiest.
On bikes "chalk dust" was used.
Happy New Year
marcel.
First learn to indentify where cracks are likely to occur. Carroll Smiths book Engineer To Win will help.
Then you will know where to look.
I would start where the big loads go in (engine, suspension and dampers) where ever there are welds and a change in section.
Sharp edges are also a common place for cracks to start as are holes. So no drilling lightening holes!
[Edited on 26/1/10 by JB]
