Hi All,
Been looking at these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370316663899&ru=http://shop.ebay.co.uk:80/%3F_from%3DR40%26_trksid%3Dm38%26_nkw%3D3703166
63899%26_fvi%3D1&_rdc=1#ht_500wt_956
Has anybody used them, and if so, when welding them to the chassis will I have to grind off some of the coating first? Cheers,
Tom
It's probably better to just get the eye-bolts and bolt them in yourself. The nut on the plate in that picture is only tacked-on.
i'm guessing the eye is suppose to be screwed in from the other side though
The idea behind these IIRC is that they satisfied the blue book having a backing plate of certain size and thickness. They will be fine and you will
probably ok without gringing before welding.
PS It stops them from pulling through a standard steel bodyshell, as above generally ok for scrutineering.
[Edited on 11/1/10 by Howlor]
Cool, think I'll order some of those then, there are some FIA approved ones that look the same and are similarly priced so I'll go for those.
The nut doesnt looery well welded on to me, and would need fully welding i think.
As mentioned above, you don't screw the eye in from the side shown in the pic. You typically drill a hole in the panel (e.g. sill) that this is to be welded to and the nut goes into the hole. When the eye is screwed in it pulls the nut up against the thick plate so the welds are only required to stop the nut turning.
I think what you need is some of these:
http://www.all-kit.co.uk/product_info.php?cPath=80&products_id=246
Got some similar to those, the plate is threaded too and yes, the eye bolt goes in from the other direction
Perhaps rivet that plate to some welded in 5mm steel then?
Will get some of those bosses for the top mounts.
Cheers guys,
Tom
You could do, Westfield use the bosses for upper and lower mounts
Why donīt you use the "Book" approach?
I`d rather buy the eyebolt and fabricate as per the book.
