Good morning all,
Has someone on this site have any influence or can contact Darren George? I have some major structural and safety issues over a De-dion axle I
recently purchased from him. I have tried e-mailing and phoneing with no luck, this is his last chance now before I go down the legal route.
Thanks in advance.
any chance its snapped in the middle?
No, but looking at it, thats the first place it will fail. This component will not under any circumstances be fitted to my vehicle. I don't want to say too much at the moment as the axle is under going weld xray and structural compliance for purpose.
I have recently fitted mine, what should I look out for?
You will want flak monkey or eddie99 - these are the two people on here who assist when GTS fail in the civilised habits of pay/supply/communicate. Best of luck.
A GTS axle snapping has happened before due to poor weld penetration, IIFC it was CalvinX’s car to but that was a while ago and I might be wrong about
whose car it was.
I have a GTS axle in my garage that I’m not too keen on selling on tbh even though someone is interested in buying it right now as I think the design
is flawed and the weld looks quite shallow. The main tube would be far better bent than welded in the middle.
Hi Yorkie,
In my case it is welds that have been completely missed off no weld penetration around the link arm mtgs excessive weld splatter (looks like someones
thrown a handfull of rice at it and then covered it in paint), the centre joint looks like they have filled a bigger gap at the rear of the tube than
at the front.
Just to let everyone know that this is not a rant but a very concerned customer. My job is a senior design engineer working for one of the biggest
chassis/coachbuilders in the world and I have been in the same field of design for 35 years, so to recieve a part in this condition has very
frightened indeed.
you got any pics ?
my Dax ones welded in the middle and I've never heard of any problems with them
[Edited on 12/1/10 by mcerd1]
you got any pics ?
Who's got the popcorn?
Stig2 - please be careful about what you write. From what you've said it sounds like there may be an issue with your axle. If you post things
inappropriately here it may prejudice any action you bring against GTS. Check with your solicitor before you say anything & it should hopefully
protect the forum from the risk of being sued as well.
A previous forum member did have an issue with a GTS axle, i believe it was sorted in the end but for reasons only he knows he left the forum some
time later and deleted all his posts / topics started. Unless the internet time machine / way back machine has his posts you're not going to find
out any more.
it was mark (calvinx) who had a little problem with his de-dion, no longer posting on this site though but i think hes still about under a different
name. so i'm sure he will u2u you
the problem he has with his was that it had another chunch of tube welded in the middle
[Edited on 12/1/10 by graememk]
Mike R,
I completely understand what you say, but if the supplier is ingnoring you what are we supposed to do? This is the reason for my original post so he
may read this and make an effort to contact me.
Will send you an U2U now
I've just fitted my De Dion from GTS got it in November and to be fair it looks ok but I going to really have a good look at it tonight I will
let you know my findings.
Looked over last night and all welds appear good - formed correctly and full length
[Edited on 13/1/10 by big-vee-twin]
Here's a link to a picture of my GTS De Dion any comments?
link
Hi stig2, thanks for the info.
I will also check mine tonight.
Someone (sorry can't remember who) cut the tube on their GTS axle close to the ends and welded in a straight bit of tube, the result was
certainly more confidence inspiring and allowed a decent amount of clearance for the Panhard rod which is always an issue with these axles.
Personaly I've never been very keen on the GTS axle design, though the link above shows the welded part can be strong enough. Whether any
particular axle would have survived the same test is another question.
I like the look of the MK design.
It's a pity they stopped offering it, I think it would out handle a few IRS cars
[Edited on 12/1/10 by fesycresy]
