Can any one clarify this:-
Just been told that the RS2000 and capri uprights are identical (geometry wise) to a standard escort apart from the spigot is 31mm higher???
hi dont know about the geometry but the spring platforms are at different heights between mk1 and mk2 escorts also the rs struts have removable
steering arms as do the 28i strut casings
Ray
what are you using them on?
[Edited on 1/2/10 by RAYLEE29]
i have rs2000 uprights on my striker. you need to make sure you get rs TRE's as the balljoint taper is different to other mk2's.
not sure about geometry though
