hi guys any +442 builders out there, can you please help with the dimensions for the wishbones.
In addition rear setup, IRS, De-dion? images would be lovely,
thanks in advance guys
regards
have a search for "rorty designs" maybe of help to you.
if i was to do it now, i would probably use the Haynes Roadster setup.
[Edited on 11/2/10 by meany]
Hi femster.
I'm building a +442 and fabricated my own wishbones. Using a Live axle (52" ).
My wishbones, unfortunately are around 20mm too short because I'm a numpty and made my jigs wrong
Still, not too much of an issue, just means the rear might be a little more lively than if I'd done them right.
There are a few piccies/ideas around on t'internet and here if you search. I found a fair bit of useful advice.
If I can help at all I will try.
JB
here you go.
http://kit-car.org/Files/suspension/RortyLocostIRSAssembly.pdf
http://kit-car.org/Files/suspension/RortyDeDionAxleAssembly.pdf
Mines a 442 and I just made standard book bones for the front ( can't help with the rear sorry as I'm a live axle) the front track is
narrower than the rear but hey it still goes and is fun regardless.
there are issues with the pick up points for the front bones though I'd need to check my build notes but there are some pics in my archive I
think.
Ask if you need any more info mate.
thanks, i would def ask for pictures soon (omega) when i gets there. Might get the GTS wishbones for the w7de though
regards
