I am fitting floor mounted pedals and have sorted the clutch and brake pedals but need to figure a way to join the accelerator cables to the pedal.
Has anyone got any good ideas or pictures of theirs?
Thanks, Mark
Don't know how its normally done but you could design a drum bass style pedal system?
Normally just a clevis I think.
stu
Hard to see but essentially on top of my metro accelerator pedal is a sphere on a small pin, I took it off the sierra pedal and welded it to the top
of my metro one as I wanted to use a standard sierra cable for ease of replacement etc, this has a barrel shaped end with a hole in the side that the
accelerator sphere goes into and the there is a barrel shaped cover that slides over the top to keep it all together.
From the pictures below hopefully you'll can make sense of the above !!!
The below isn't off my car but shows the assembly a little clearer.
Image deleted by owner
Rich
[Edited on 13/3/10 by RichardK]
i have the same problem
im going to a drill a hole though the bar then weld a tube to it that a screw on nipple with go inside to stop it moving to much
How about something like this.
I made the metal bit from a piece of stainless strip and the cable attachment was from CBS I think.
Cheers guys, now to decide :0)
