some basic dimensions please
Kartdad - 28/5/10 at 06:23 PM
As it is going to rain for the next two days I hope to make some progress on the locost. I am looking for two dimensions please
1. Height from floor to centre of steering wheel, I know there will be many opinions on this but a range of dimensions will help
2. The inside or outside radius of the rear top rail corners for luggage compartment.
Many thanks for any guidance
KD
[Edited on 28/5/10 by Kartdad]
mark chandler - 29/5/10 at 10:31 AM
Best to fix the pedals and seat in position then add steering wheel late in the build so it suits you for both rake and height. The position may be dictated by oil filters, alternators, engine mounts etc.
I used 3/4" round tube bent using a 22mm plumbers bender for my top rails, for the lower picked up a 1" steel tube framed chair and cut out the bends.
Regards Mark
