Over the weekend I am going to put the weight of my engine on to my chassis for the first time. I don't want to create any local stress areas.How big should I make the mounting plates?Thanks Glan
What ever size you make the plates they still put a big bending load on the lower members what is required is an extra tube at each side to take
the loads to a vertex.
With a spaceframe the loads should always be at vertexes where 3+ tubes meet as the tubes themselves have no strength/stiffness in bending .
It isn't always possible but the loads should be fed in as close as possible to the corners of bays.
Originally posted by britishtrident
What ever size you make the plates they still put a big bending load on the lower members what is required is an extra tube at each side to take the loads to a vertex...
And then weld the plate to support the mountings.
