Since i haven't seen anyone else asking this and although i am not building anything at the moment here goes The silliest question of the
century.
Without considering cost implications
What is better if you use round tube for chassis?
straight tubes welded or a long tube mandrel bended?
was thinking if getting a 7m long tube mandrel bended in the same points as the square tube.
[Edited on 24/9/10 by l0rd]
Worth checking but a lot of the thin wall stuff is made in 6m lengths
I wouldnt even atempt to bend it that long and get any accuarcy.
It will be weaker, not a good idea
Originally posted by big_wasa
Worth checking but a lot of the thin wall stuff is made in 6m lengths![]()
Didn't Robin Hood used to do this? I seem to remember they advertised not having any joints at any of the corners.
Putting bends in at the outset cause a weak point as you have already bent the structure, okay it may be at the end not the middle of a length but it
will still collapse here as the load is not pointing at the joint.
[Edited on 24/9/10 by mark chandler]
Putting bends in at the outset cause a weak point as you have already bent the structure, okay it may be at the end not the middle of a length but it will still collapse here as the load is not pointing at the joint.
I see no reason for it to be weaker, it will be weaker than before it was bent as it's suffered compression & tension deformation but a
welded joint is even more compromised.
The real problem will be getting the bends in the right place & angle relative to each other, it'd take a bit of experimentaion &
practice before you start for real.
A thing to consider first though is are you solving a problem by making it that way? How much of a problem do the welded joints cause, are you solving
a problem that only exists in theory?
There'd still be a lot of welded joints anyway, you'd only be able to do the top & bottom rails really, the rest is pretty much straight
lengths
Originally posted by hillbillyracer
I see no reason for it to be weaker, it will be weaker than before it was bent as it's suffered compression & tension deformation but a welded joint is even more compromised.
The real problem will be getting the bends in the right place & angle relative to each other, it'd take a bit of experimentaion & practice before you start for real.
A thing to consider first though is are you solving a problem by making it that way? How much of a problem do the welded joints cause, are you solving a problem that only exists in theory?
There'd still be a lot of welded joints anyway, you'd only be able to do the top & bottom rails really, the rest is pretty much straight lengths
I was dead set on doing a round tube chassis because it'd be better & worth the hassle of fish-mouthing ends of tubes etc. The I went to a
hill-climb & folk were driving their sevens much harder & with more power than I probably ever would & all of them had square tube chassis
so I decided that it'd do for me too & save much time & hassle
Then I went & bought an unfinished project as it'd get me on the road so much quicker & I cant find the time to do much with it so I
doubt I'd ever have got far with the round tube!
Not quite sure what you mean exaclty, but a space frame chassis is made from straight tubes and "point" intersection, tubes are only in
compression or tension this is why the space frame from is strong (with triagnulation).
An uncooked piece of spaghetti is very strong under compression/tension but as soon you but a bending load on it will snap.
A bend in a a tube between the fixed end point will weaken the tube, it will first fail under compression/tension at the bend..
Dan
All true enough, but taking the following isolated part of a spaceframe which is stronger, the one with the bend, or the one with the cut and weld?
We aren't comparing a bent tube to a straight tube, but to two straight tubes at an angle with a weld.
I think in isolation both are probably very close in strength (once taking into account weld quality, cutting accuracy etc.)
The problem with the bent one is it's much harder to triangulate into the bend to make a spaceframe, compared with the cut and joined version,
but there are plenty of places in the non-ideal spaceframes we use where such things could be used (for example the BR1, BR3, BR5 bottom rail on the
haynes roadster, which could be fabricated as a single tube with 2 bends if you had the equipment to bend it accurately enough)
The problem with the bent tube robin hood 2b chassis was they didn't bother putting in much triangulation.
Originally posted by iank
(for example the BR1, BR3, BR5 bottom rail on the haynes roadster, which could be fabricated as a single tube with 2 bends if you had the equipment to bend it accurately enough)
Off the top of my head, without having the Haynes book in front of me for reference, I believe what you proposing has crossmembers welded at these
points?
I.e. there is a point of triangulation attached on the inside of the bend point, so its not as if the bend is 'unsupported'
Am I following your thinking? In which case I would imagine it pretty much equal in strength, but nicer looking
The Blessed Colin (we are not worthy) called bent tubes 'pre-failed'
Originally posted by Rod Ends
The Blessed Colin (we are not worthy) called bent tubes 'pre-failed'![]()
Bent metal will have "necked" during the plastic deformation (Thank's Poisson) and therefore will be a thinner wall thickness on the outer edge of the bend, possibly stayed the same on the inner (depending on bend method) and therefore have, overall, lost strength depending on load direction. During a cut and weld, assuming the weld is done well, the filler material and the weld will actually be stronger than the original material (thicker, possibly higher strength filler material used-depends on the weld), but you need to consider heat effects in the surrounding tube. If this is kept in check, the weld would be stronger IMO. So in essence, I agree with the bends=pre-failed concept.
MNR do all their chassis in round tube now that they have a tube bender. They bend long lengths to shape. The tube is not weakened if the triangulation supports it at the bend. It is then a series of straight tubes but with bent rather than cut and welded nodes.
Suspect part of mnr's reason for bending is speed of fabrication.
Suppose this is more relevant for thin walled tube, as roll cage for example have to be bent (for certain regulations), at key corners, & not
welded....
But then they also have to be a minimum thickness
That's due to the unquantifiable quality of welds I think. They want something certified and of a fixed, known strength, rather than it being the
best way of doing it. If you can fix the material and construction you can know the strength. If you just fix the material and get a moron to weld it
you could have a useless crumpled mess in an accident. It doesn't mean the method is stronger.
[Edited on 30/9/10 by coyoteboy]
Agreed...
I suppose the train of thought is almost, bend it if "one's"* not confident of "one's" welding proficiency - though that
raises the question whether you should be let loose on making your own chassis!
(* not directed at any one!)
I probably shouldn't
Out of interest, and accepting the fact that a bent tube will have thinner sections etc, but would annealing the tube after bending help, by reducing
the stresses from bending?
Jus' wondering
I don't think there's sufficient material in most tubing to have residual stresses to worry about.
