Evening all...nearly ready to remove engine and box ...but...problem 1 is the gearstick is not coming off union i have the lower pin removed ..it should come off...mine is cetainly not !!! Problem 2 propshaft bolts are solid ...just got hold of a bigger impact gun to give it a good doing tomorrow !!
To get the bolts of the donut I just choped them of with grinder then got the impact wrench on them.
Do you mean taking the stick out of the white plastic bearing ? There is a circlip.
I thought it seperated just below the hole where the pin goes through ..??
Ah the top bit for the lift reverse. Its tight but pulls of.
I binned mine and turned one up on the lathe.
[Edited on 20/10/10 by big_wasa]
