I have bought a Tiger Cat rad. It doesnt have any mointing brackets. Does any one have any Tiger pics to show how it was originally mounted.
What suggestions do you have for a locost rad to suit?
Cheers.
If it was the same as my Super 6 it was sat in 2 brackets at the bottom and had a single bracket at the top.
old rad
I assume that some rubber or foam padding is used between the rad and the bracket?
That's the very one. Looks quite simple. I may need to also fabricate side brackets, to keep it in place round the bends!
I used little ali brackets from Wilkinson!
