Hi all,
Wasn't sure if this belongs in this section but seems the best place.
Basically I was to make some new mounts for my pinto engine I have everything I need apart from the rubber bushes and the steel sleeves like the ones
in the link below
Engine mount kit/105e/100e/cortina/capri/classic/ford | eBay UK
Just wondered where the best place to get them from is.
Po.
something like these Land Rover Defender Front Radius Arm Axle Bush NTC6860 | eBay UK
they may be a little big.
why not just ask the seller if they can just do the bushes on the own
Yeah I did mean to drop them a line,
Got a feeling they'll be at a premium price given there charging £55 for a couple rubber bushes, a couple plate of steel and a bit of tubing.
Just figured it would be cheaper going to a company that supplies the bushes and cut out the middle man so to speak. I thought a lot of guys on here
would have done the same and could suggest what companies are best to use.
Po.
