I'm fooling around with the scanner (new toy)
This is obvious going wrong!!!!!
You can change their size in an image manipulation program ( Photoshop type) or you can scan them at a percentage of their original size.
I know Pete it looks like s@#t but i know not much about this computer stuff.
If anyone can bring it (the drawing i mean to a reasonable size....
Here they are. If you export them as .jpeg you can cut down on their quality and still show them but save space and time uploading.
Is that a swingarm monoshock rear suspension? What are you using for roll control?
I meant for general pictures for web publication really. The ones on there are .bmp, check the properties. Look round on Google for scanning tips.
This one came up.
http://www.scantips.com/simple.html
It goes into great detail on lots of different subjects.
Crbrlfrost,the pictured sketch was an early drawing and i intended tu use a sway bar.The comments, especially from Rorty,made me think again and
perhaps it's not such a bad idea to go for a live axle without a diff on such a light car.
It surely would simplify things but the monoshock idea would'nt work on this i think.Since i use a chain to drive the rear axle the suspension
can be a simple craddle like construction on which the rear axle is bolted.This craddle can move up and down with only a slight variation in distance
decrease towards the engine sprocket.A Panhard rod will keep things more or less centered.
Dont know if it work's but gonna give it a try anyhow.
