on with making wishbones atm, but struggling to find a place that sells the threded"tube" if you like that the transit track rod end threads
into... is there such a place that makes them?? i could drill some stock i have and buy a tap and prat about making them just would prefer buying
them...
any ideas?? i will get around to posting pics guys... honest!!!
Have you considered camber adjusters instead?
i havent no... not sure what is involved in that?
if you would care to elaberate... im now intreaged!!!!
Originally posted by donskye
on with making wishbones atm...
Camber adjusters - allow you to adjust the camber without removing the ball joint from the upright. In order to do this you use a plain tube instead of the threaded one on the outboard end of the wishbone and then there is a threaded insert with a hex on one end that fits inside the plain tube. To adjust camber you release the lock nut on the ball joint, twist the camber adjust until the desired camber is achieved and then tighten the locknut again. Very simple and makes the wishbones easy to make too.
Try these Poeple for threaded Weld in Insets
here <-----------------
[Edited on 2/1111/11 by mad4x4]
cheers boys ur a gr8 help!!!
I would send David Flak Monkey a U2U.
