Has anyone ever taken a front engined kit chassis and converted it to midi?
My tiny brain is in overdrive again and I've come to the (temporary) conclusion that it should be fairly straightforward...
... measure lots
... narrow the trans tunnel
... take a bit off the front
... add a bit on the rear
Job done!!!
Anyone have any real-world experience on such a matter (instead of my airy-fairy it's-a-piece-of p** logic ).
Or do I just buy Ed99's old Global chassis and see if I can adapt it to take a car engine!
By the time you have dismanteled it, you might as well start from scratch!
You buy my old global chassis and adapt it for a car engine. Sorted Only needs extending a tad
Simples...
[Edited on 9/1/12 by eddie99]
... measure lots
Job done!!!
Simples...
If your building a chassis dont see why you couldnt narrow tunnel to get more room and move the diff mount seat panel frame part forward leaving more
at the back overall dims would be same as book but would have to narrow scuttle and shorten bonnet very interested if you have a go
ALI
Cheers Ali
It seems quite straightforward in my head because I'd (hopefully) be starting and working within a 'straight' structure.
Would it not be worth looking at a MK Midi or Sylva RIOT chassis?
Hi Scootz are you going down m6 past penrith on friday think we are going to auto sport on thursday
Bang on you fly striaght over me maybe you could paracute the tank out
does that mean the kv6 has been shelfed ? Did you get as far as getting the engine ? Ive just bought a very rare toy to sit on the top of mine
Nope... KV6 is sat in my garage!
I'm struggling to find an 'off the shelf' bellhousing to use it longitudinally, so I'm exploring the option of going transverse in
a midi set-up using either the PG1 or Getrag 283 boxes.
[Edited on 9/1/12 by scootz]
Originally posted by zilspeed
The ability to think in three dimensions is not given to everyone, clearly.
I can indeed think in 3D Zil, but I'm still not all that convinced that the MK back-end would be too happy with an engine / gearbox combination sat in it that weighs 3 times that of the intended bike-engine application and puts down almost 3 times the torque.
Regarding that engine.
Where do you want the weight of the car to be ?
Think of it that way.
Percentage wise, what do you want each tyre to take ?
Scootz
I wasn't talking about you...
Meant to add that I'm not all that convinced about the strength of the rear-end of the MK Midi...
I'm struggling to find an 'off the shelf' bellhousing to use it longitudinally, so I'm exploring the option of going transverse in a midi set-up using either the PG1 or Getrag 283 boxes.
Cheers Mark.
I've established that the KV6 has the same engine to bellhousing bolt pattern as the Rover 'T' series engine... and therefore the
'O' series too... so that leaves only two RWD options. The Rover SD1 (2 litre engine variant) or the Sherpa (prima perkins engine
variant).
Neither come up for sale often, and both have anchor-heavy (20kg's) iron bellhousings.
Didn't the GTM Libra use a KV6? Monocoque I know, but made a great grand tourer I think!
T'is indeed. I'm not a big fan though.
Hi Scootz,
My car is based on the book, but done the changes you have described. Its very doable. Go for it!
Rob
Cheers Rob. I've had a swatch through your photo archive... keep us posted!
Thanks Scootz, if you need any advice or help give me a shout.
I will be updating as I go, working on a special part at the moment, but don't want to post until it's finished.
A bloke I knew many years ago started building 7 style chassis at his workshop. After a bit of success with the 7 he branched out and made a middy to
take the Toyota 4AG engine/gearbox. I never drove it but it looked OK. Keith was no engineer and he did the design on the back of a cornflakes box.
However, the front of the car was all 7 because he had a jig for it. He made another jig for the rear subframe to take the 4AG and then welded them
together.
No record of Keith exists on the interwebs, I looked. He bailed out of the kit car game over 15 years ago at least.
Although not using an existing chaccis I’ve seen it done based on 7 type chassis plans, once based on a tiger and another that’s featured in a couple
of mags, initially it had a Renault turbo engine and corisponding transaxle.
The basics are as easy as you suggest. Basically take the chassis cut out the portion between the footwell and the front suspension (your engine bay),
move the front suspension back and do whatever is required to make it stick there. Separate the rear suspension portion and move this back until you
have the wheel base/engine bay you need. Now attach this with longer tubes. Finally make anything that looks like a rectangle into triangles with
additional tubes, done!
Anyway I like your choice of engine but would hate to see it sat sideways, that’s just wrong for a midi in my mind, makes it more like rear engined.
How about an Audi transaxle and an adaptor-plate?
