1. in the book it says to use a 16swg steel sheet for the floor, but would 1mm be enough?
2. will i have to make any modifications to the transmission tunnel to fit a t9 gearbox?
I built book chassis and fitted a type 9 no probs
In the book its says you should use 16g for the floor or use the roof panel from the (Escort Mk2) donor. The roof on the essy is only 20g (0.9mm) so I dont suppose it matters?
that's what i was wondering, because all the roofs i've seen so far seemed to be about 1mm, so i thought that the old escort may have had a thicker roof.
I expect that in the book 16swg was suggested because it is easily obtainable, not because it is the minimum thickness suitable
John
I have got 2 sheets of 16swg steel and I don't think I'll be using it, it's way too thick in my opinion, I'm sure I can make use of it on some other project.
I used 20swg sheet steel. It's OK but I had to fit a couple of additional cross members afterwards as when you stepped into the car the floor wobbled and distorted. OK now. For weight reasons I wouldn't have used 16swg.
the crossflow box and t9 box have the same size bell housing just swapped them over this weekend and they fitted fine with the exception of the base rail by the starting motor got a bit closer there than before.
