Didn't really know where to put this thread so decided to put it here as it is part of the chassis build i suppose.
If I build a tank following the book, could someone tell me what litre tank it would be? It's just my engine is going to be very thirsty and will
be used on road too.
Cheers!
Or if someone could recommend me a size, even better!
Just do a search and there are loads of places to get it!!
http://www.petfish.net/calculators/calculate.php
Simple maths to work out the volume of the tank, LxHxW in mm!
10cm x 10cm x 10cm = 1lt
Could someone please help me workout the volume of this tank please?
Just tried to do it with the link provided and was told it was over 6000 gallons. Don't think so. Measurements were converted correctly too.
Without working out the exact shape of the tank, it's in the region of 26 litres.
Needs to be bigger, will be road legal too and running about 300-350bhp, will soon empty that. Will just keep the same width and length and make it taller by another 10cm or something. As long as its about 35 - 40L it will be al right I think. When on the track I will just half fill.
Using the link provided, and rough measurements, as the link assumes a rectangular tank, it comes out at roughly 6.5 gallons. Using the measurements,
which I'm not sure would actually make a real shape, it's 24.5L.
And please don't take this as an insult, for I know maths isn't everyone's forte, but for someone building the kind of car you're
talking about, you should be able to figure out the volume of a fuel tank.
Hi there and thanks for your input.
I am a lathe operator and a specific machinist. Just never had anything to do with volume and didn't know the formula.
Cheers.
I now know my size i will make my tank too.
My front mounted tank is going to be a queer shape, so shapes have been in my head while I decide on shape & volume. While making a coffee I was
pondering cylinder shapes, before I knew it , I had emptied the 32L pedal bin and had it tucked under the bonnet of the fiat.
Just to get a general idea. Im currently trimming and shaping 2 x Budweiser boxes taped together. Most I can hope for is about 5 gallons.
Hi mate.
Thanks for your ideas! .. Will have to do some cutting and shaping of my own just to get an idea of its actual size!
Going to make it the same size as the one recommended in the book (if it is to be said 26L roughly) i will just make it a few CM taller just to make a
bit closer to the 30L mark. will be happy with that.
All the best.
