hi all striker owners
as said from my previous posts io would post up some pics of the chassis bracing i done,
you may crisique of course and i am unsure how it will all
work, but hey we have to try,
pic of front strut brace, this goes between the 2 supsension pic up points to add strngth when under hard braking as there is on triangulation in the
engine bay to support this area just and 1.5" braket that the top rocker bolts into, i am hoping that with this in place it will fight each other
under braking taking stress from the brakets???
front strut brace
next is the rear and the same again as bolts between rear diff and two pick up points for the top A arms, as i see that they are mounted in the middle
of the bar ie weakest point with noting triangulating it for support so under load again ie braking / acceleration will def move, althought this is
just flat bar it should help i think??? and im tight for space but it is all along the same plane>
of course comments will follow and i welcome them if you think its crap or can improve etc,
thanks
sean
Looks good to me Sean, but I just want to see pictures of these new wheels fitted
It's coming I Thought I was getting my uprights back sat but not done yet, poss tues now grrrr,
Still new rear 10" wings fitted so can't wait now, all car is waiting for is the wheels to go on,
Thanks Paul hope you enjoyed Newark?
Sean
