A few dimension queries if i may
Padstar - 5/1/13 at 10:58 AM
Chassis is nearing completion but i have 2 queries that i would like to get put to bed this weekend that wil allow the chassi plates to be connected and hopefully move me on to the next stage.
Can you tell me what the dimension between U8 & U9 (shown in the diagram bellow) should be as mine seems to be slightly to far appart for the tunnel brace to fit well.
Toprails
Toprails
Also what should the dimension be between TT7 & TT10 (shown bellow)? I guess this is for the gear level brace of handbrake?
Tunnel
Tunnel
Talon Motorsport - 5/1/13 at 11:13 AM
Measurement between U8 and U9 is 195mm same as the haynes. Leave TT7 and TT6 out untill you have the engine and gearbox fitted.
Padstar - 5/1/13 at 12:14 PM
Many thanks do Tt5,6,7&8 hold the gear box housing?
Talon Motorsport - 5/1/13 at 01:51 PM
Gear box has a rubber mount that needs to go in there some where but I've never had one to see where it goes.
Hopley89 - 6/1/13 at 11:16 PM
Hi padstar Iv just finished my chassis for a haynes roadster I used 25 mm box on all of it I followed the box step by step an all my clearances are good
Dan
