1.2mm or 1.6mm for floor panel
MK9R - 14/2/13 at 03:38 PM
Just about to replace floor on the fury, going to use NS4 or T6 ali sheet, but what guage, 1.2 or 1.6??
Daddylonglegs - 14/2/13 at 04:13 PM
I'm no expert but 1.6mm seems a little optimistic for a floorpan? My Ally floor on the Locost is 2mm.
Someone with more knowledge than my humble self will be along soon I'm sure
[Edited on 14/2/13 by Daddylonglegs]
sdh2903 - 14/2/13 at 04:16 PM
I would have said 2mm as minimum thickness.
procomp - 14/2/13 at 04:55 PM
Hi Austen.
Only ever used NS4. 1.2 mm. Just make sure you have a cross member just in front of your backside to reduce any flex in that area. Assuming that you are bonding and riveting to a decent standard.
Cheers Matt
motorcycle_mayhem - 14/2/13 at 06:16 PM
1.2mm was ideal on my Westfield (430Kg Megabike), supplied by the factory at the time. My Sylva-derived car has 1.6mm, feels very thick and heavy by comparison. Thing is, the Westfield has two 2" steel strips across the floorpan on which the seat sits, the Sylva-derived thing doesn't, the seat bases go straight on the alloy. Rivet spacing is very generous on the Westfield, very tight on the Sylva-thingy.
2mm sounds great for rallying....
eddie99 - 14/2/13 at 09:12 PM
We use 2mm t6 but that's to add stiffness.
Also means that no kerbs or bumps will damage it and should last almost forever
b3ngy - 14/2/13 at 10:00 PM
Not long replaced mine with 2mm thick aluminium, can't remember what grade though.
MK9R - 14/2/13 at 11:39 PM
mmmmm, its replacing the battered floor on the old Fury, which i reckon is 1.6 standard bendy ali, tempted to drop down to 1.2...... Saves 2.5kg mmmmmm
[Edited on 14/2/13 by MK9R]
AdrianH - 15/2/13 at 12:04 AM
I know I like overkill sometimes but my 1.6mm steel floor certainly stopped something hard coming through. what ever it was left about a 10mm dent in the underside of the trans tunnel.
It's down to what roads you use and if lots of track days, I guess.
If you need to end up bracing with steel will you save that much weight?
Adrian
[Edited on 15-2-13 by AdrianH]
hughpinder - 15/2/13 at 07:59 AM
The sylva riot is 1.2mm NS4. I plan to use 1.5 because its felt a lot less flexible and was only a few of quid extra.
Hugh
TimC - 15/2/13 at 08:26 AM
1.2mm NS4 for me.
But.. I am sat atop these.
jps - 15/2/13 at 08:56 AM
Not sure on the thickness, but i'm planning on using an old pub sign as my floor - which I think is at least 2mm alu. My seat runners are going to be mounted on 25mmx3mm strips running width ways across the car. I'm not too bothered about the extra weight, more interested in having some serious @rse protection in place :-D
whitestu - 15/2/13 at 12:40 PM
I tend to do the opposite - I use the pub floor as a sign [that I've had too much beer].
I'll get my coat.
stu
Ivan - 16/2/13 at 07:39 AM
^ LOL
hicost blade - 16/2/13 at 10:01 AM
Btw for anyone who actually wants to buy this material in the year 2013, it's now and has been for sometime called 5251.
will_08 - 16/2/13 at 11:07 AM
When i last looked into this, i thought we were looking at 3mm Ali, 2mm steel min?
Or is that really overkill?
Will
iank - 16/2/13 at 11:51 AM
Will
Yes that's extreme overkill on the steel even for a road car, a tin-top will have 1mm steel floor but shaped so you don't get the "boing" effect.
When using NS4 / 5251 you certainly don't need more than 2mm unless you plan on driving over bricks on a regular basis.
For a racer enough to keep your bum off the road and water out is as much as you need.
Doctor Derek Doctors - 17/2/13 at 10:30 AM
I used 1.5mm thick 5251 for racing, next time I'll drop to 1.2mm 5251 though.
