How much box section?
john-t5 - 27/9/13 at 03:00 PM
Sorry if this has been asked before. Done a search & could'nt find anything.
Just looking for a starting point to give me a rough idea of cost to build a Haynes chassis. How much box section should I need to order?
Cheers John
joneh - 27/9/13 at 03:13 PM
6 lenghts of 25x25x1.5mm ERW
2 lenghts of 19x19x1.5mm ERW
Lenghts tend to be 6m.
Or add up the numbers in the back of the book!
iank - 27/9/13 at 03:15 PM
Bottom of this page for a cutting list
http://www.tamarisktechnicals.com/pages/roadster.html
ETA agrees with joneh
[Edited on 27/9/13 by iank]
Andy S - 27/9/13 at 03:17 PM
And then add 50% more for all the times you only measured once -
Volvorsport - 27/9/13 at 03:32 PM
http://www.locostbuilders.co.uk/viewthread.php?tid=185504
john-t5 - 27/9/13 at 09:30 PM
That's more what I was asking. Not bad at cutting, but realistically I'm not going to get every one right. I'm sure most people are the same.
Cheers John
Slimy38 - 28/9/13 at 08:27 AM
So far I reckon I've wasted about a metre in offcuts, the only major cockups I've made were on the front part of the suspension as the measurements I had were wrong (too short!). Turns out it was a blessing in disguise as Phil at Talon described a much better way of putting it together.
I cut my pieces as I went, only doing two at a time where they are a matching pair on either side of the car.
I went for 6 x 25 and 2 x 19, as joneh describes.
[Edited on 28/9/13 by Slimy38]
