I've just bought a part finished (but well made) book chassis and bits. The chassis is pretty much complete and the seller supplied home made top
and bottom wishbones.
The welding on the bones is excellent so i'd like to use them if possible but here's the crunch.
The bones have been fabricated using the Lolocost bush eyes and Lolocost black nylon bushes which I would prefer not to use as they seem too hard for
my intended use (road/very occasional trackday).
Does anyone know a supplier of polybushes that have the same dimensions as the Lolocost nylon bushes. i.e. OD (of the section that inserts the eye)
25mm, ID (bore) 14mm (approx), length = 21mm (approx)?
Many thanks
Gary
hi,
i've a pair off avon tiger wishbones and need bushes the same size (25-26mm)
any ideas where
i can get a set off 8
cheers chris.
Try giving rally design (www.raldes.co.uk) a ring - they may be able to help with their polybushes, especially as you have the dimensions to hand.
cheers steve, will give them a try.
thanks chris.
