Anyone fancy to design your own chassis?
If interested, I have the following parts that will help a lot that endeavor!
Ideal to design and produce an ultimate track day car!
Please, refer to the first photo, to understand the following parts list/legend:
A- Chain driven diff aluminium side supports;
B- VW Based CV joint (diff side);
C- Rubber boot;
D- Wilwood 11” vented brake disk;
E- Alloy disk bell;
F- SKF hub/wheel bearing unit (Opel/Vauxhall 4x100 PCD)
G- Upper Rear suspension arms;
H- Inboard suspension connecting rod (rear suspension);
I- Inboard suspension connecting rod (front suspension);
J- Front axle blocking bearing washers;
K- Splited sproket
L- Chain driven diff (alloy casing, with excentric adjusting system, standard VW diff inside. It is possible to use a LSD);
M- Custom made transmissions;
N- Rear upright arms;
O- Rear 7075 T6 alloy uprights (designed to use SKF unit and wildwood callipers)
P- bottom ball joint support (bolted to upright);
Q- Bottom rear suspension arms
R- Suspension bell cranks;
S- Front upper suspension arms;
T- Front bottom suspension arms;
U- Front 7075 T6 alloy uprights (designed to use SKF unit and wildwood callipers);
V- Front upright steering arms;
Will provide all info needed and will help setting up the design you need. 3D CAD data available for all parts listed.
Regards,
Ernesto Freitas
How much are you asking for the items?
