I have a very early Robin Hood S7 Monocoque based on a Dolomite 1850. Does anyone know if the rear anti rollbar from the dolomite was supposed to be fitted to this kit? An Original build manual specifically mentions that the the front one is not required but doesn't mention the rear one. Any help would be appreciated.
Welcome to the Madhouse from a fellow S7 owner!
Not sure whether it was meant to be fitted but I know you can run a dolomite with or with out, so I would say try it both ways and see which you
prefer.
If you want a definitive answer probably best asking on rhocar.org
[Edited on 20/3/14 by theduck]
No you don't have the anti roll bar at the rear, or at least I didn't on mine.
Maybe I should have and I wouldn't' have rolled it over a hedge!!
Thanks for the replies.
Monocoque based on Dolomite?
i had a dolomite-sprint based robin, years ago,...this car had a kind of spacefame, with the complete dolomite front crossmember adpated.
depends on the dolomite donor model it might be possible to have an antirollbar or not.
[Edited on 23/3/14 by alfas]
