Hi,
Having done some research into the radiator for my Fury I wonder if someone could do me a favour and measure their Polo radiator fixing points?
Reason is, I was told the Fury mounting points are to accept a mk2 Polo radiator (85-90. 1.1-1.3 number 171.121.253 CF or CJ) which has a core
dimension of 430x 320 however I also know that the person who collected their chassis before me had his mounting points in the wrong location.
The measurements I have for the chassis are in the picture below, 460mm centres x 180 centres. I want to know if the Rad details I have will fit
properly without me having to make up some brackets?
Rad-fixing
Maybe of no use (different size rad). Polo MK1 fixing centres are 414 x 180.
Thanks Smoking Frog,
The Mk1 will be no good then. I was hoping someone with a Mk2 rad would send in the dimensions, I know there are loads with them fitted.
Some Ebay auctions have the measurements on the pictures, for example;
VW POLO 1.7 1.9 SDI 96-99 MANUAL RADIATOR NEW
Although I think the width is measuring the wrong thing? I'll see if I can find another.
I've got this one (1983-1990):
http://www.ebay.co.uk/itm/281080612617?ssPageName=S
TRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The mounting holes are approx 415x180mm apart.
VW POLO 1.7 1.9 SDI 96-99 MANUAL RADIATOR NEW![]()
I've got this one (1983-1990): VOLKSWAGEN POLO 1983-1990/DERBY/SEAT TERRA/KIT CAR RADIATOR NEW-2 YEAR WARRANTYTRK:MEWNX:IT&_trksid=p3984.m1439.l2649 The mounting holes are approx 415x180mm apart.
I've had 2x polo radiators. Same model, but different brand. The spacing of the pegs on the bottom were slightly didn't. Around 6mm
overall. I ended up having to modify the bottom brackets to be able to fit the replacement radiator
Originally posted by Davey D
I've had 2x polo radiators. Same model, but different brand. The spacing of the pegs on the bottom were slightly didn't. Around 6mm overall. I ended up having to modify the bottom brackets to be able to fit the replacement radiator![]()
Go onto www.northernradiators website. They used to have all the dimensiond on there. And they were cheap.
s
