I'm currently looking to sort out my bolts (having failed to find anything other than stainless at Stoneleigh) but the sizes are proving
difficult to find all in one place. Can anyone tell me how long is the threaded portion of a bolt, just so I can see if the next size up/down would
work?
And I seem to remember that using fully threaded machine screws is frowned upon, is that correct?
Depends if you're using metric or imperial, and they come in dozens of sizes, usually starting from about 2 diameters up to about 30 diameters, in steps of 5mm (metric). If you're using them for structural components you want the load carried through a shank rather than a threaded section wherever possible.
I know they're stainless and you don't want stainless but checkout the sizes available here:
http://pts-uk.com
NTDWM but I use them at work.
A chart here
Originally posted by 40inches
A chart here
About 7 posts..........
I'll get my coat!
A chart here
Perfect, thanks! I knew it would be somewhere, I just couldn't think of the appropriate Google search!
As above.
My normal suggestion is "find a supplier and work with what they have" as it'll bite you in the ass if you think you can buy
"standard" fastener lengths! (I speak from experience, after electrical connectors, fasteners are by far the biggest pain in my ass from a
design point of view!).
Thanks for the replies. I found a couple of suppliers that used the DIN references so now I know what to look for I was able to get the full set. I
bought the majority of bolts from one place, but the larger bolts for the lower rear wishbones had to come from elsewhere. They were all 8.8 DIN931 so
fingers crossed they should be ok.
Now to find the nut covers for a decent price... I don't mind those being cheap Chinese knockoffs...
^^ DIN931 will be fine, its more or less the same as the ISO4014 bolts
FYI both of those standards cover production grades A and B - basically grade A bolts are made with slightly better tolerances
