mx5 engine and gear box in "book chassis"
threadbare wallet - 22/6/14 at 06:38 PM
I have a luego locost which as far as i know is "book dimensions" i have a xflow at present, i have been planning on a zetec conversion with a type 9 gearbox over the winter but with the prices of decent gearboxs going up and up i have been considering a mx5 engine and gearbox instead,any one done it in this chassis? Is it easy enough ? I cant find much info on here or else where. In the states theres a bit but that seems to be from those that are building from sctatch with the engine in mind. Will the geatbox fit in easy enough? I dont mind a bit of cutting of a tube or two but i dont want a whole redisign.i have a solid rear axle so i guessthe prop shaft would need to be made up but that wouldnt be a problem.also can they be run on oe ecu's? I like the idea of stock ecu's where pos.and how much different is the 2.0 from the newer mx5? I presume its the same as the ford duratec but with a rwd gearbox.
rash12 - 22/6/14 at 07:30 PM
hi if you are close by your welcome to come and measure I have an engine and gearbox in the garage if that helps you at all, where abouts are you im in Scunthorpe north lincs
threadbare wallet - 22/6/14 at 07:43 PM
Thank but i'm in kent so bit of a trek lol.but if you get a chance the width of the bell housing would be handy. Thanks
Dick Axtell - 22/6/14 at 07:57 PM
Hello,
If he hasn't already replied, check out JAG on this forum. See - http://www.locostbuilders.co.uk/viewthread.php?tid=184610. His is running still!
rash12 - 22/6/14 at 08:04 PM
16 inches would give you a little clearance
threadbare wallet - 22/6/14 at 08:18 PM
Great thanks for the rapid reply time for a load of measuring.
rash12 - 22/6/14 at 08:24 PM
good luck mate
