Hi folks,
Did someone already use the drawing which can be downloaded from http://locost7.info, called 'New+sierra.dwg'? Are the IRS and front susp.
dimensions correct?
Thanks for replying!
Joost
The Netherlands
I think one of your countrymen did
I did use it for my first car but I changed the suspension.
http://seven.dp-graphics.nl/project1.htm
Hi fellow,
Happy enough I'm not the only one in Holland building a sportscar. We live in a small world after all...
What was the main reason to modify the suspension. Can you tell me what you modified?
Groeten,
Joost
