Hi
I'm looking to make then height-adjustable suspension on my fury, and need help finding a supplier.
I'm after wishbone receiving brackets, that look a little like the picture below
I've seen similar brackets on single-seaters, kind of like a triangle shape. The bracket receives the rod end, and then can be bolted to a plate
with stepped holes to adjust the height.
Also, I'm after 10mm rod end bearing housings - I can find 1/2" from McGill Motorsport, who were my first port of call, but am struggling.
They don't have any of the above on their website. I could cad this up and have it machined, but I'd far sooner go off-the-shelf if
possible.
Thanks in advance for your help.
M
Don't AB use something like that on the Sabre?
