I know it's been asked loads of times can anybody recommend the above...just want to get some prices.
I used these guys:
http://www.controlwaterjet.co.uk/
Great for small volume stuff, really good service
I used these guys before:
www.h2oprofiling.co.uk
'pathfinder' on here had something to do with them at the time - linky:
http://www.locostbuilders.co.uk/viewthread.php?tid=186146
[Edited on 3/3/2016 by mcerd1]
www.lasermaster.co.uk
Used them a couple of times for Aluminium (upto 10mm) and Steel, quick quote turn around and job done well and quickly (both *.dwg files I supplied)
another vote for lasermaster
As you are in Lincoln, not too far south from you in Spalding / Pinchbeck is Laserfab (part of Gutridge Engineering).
Not used them for laser work myself, as my company has our own laser workshop, but I have heard good things about Laserfab.
Doncaster laser were the cheapest around by far when I needed some parts cut out
What sort of ball park prices do these companies charge? I need to make 4 mild steel thin quarter panels plus up to 6 smaller trim bits to skin the
wood frame on my MG TC. I can buy the steel off e-bay and cut them myself with a saw using the ond rusty ones as templates, or I guess that I could
get them water cut.
Its not a huge job to cut them myself, but if its not too much to get them water cut, I might go that route to save the job and get a neater finish
(plus I guess that there will be a small saving in the unit cost of their steel stock that would off-set their price for the job a little bit).
My experience is 50 quid set up charge, plus material, plus a repeating cost per part is about normal.
Originally posted by SteveWallace
What sort of ball park prices do these companies charge? I need to make 4 mild steel thin quarter panels plus up to 6 smaller trim bits to skin the wood frame on my MG TC. I can buy the steel off e-bay and cut them myself with a saw using the ond rusty ones as templates, or I guess that I could get them water cut.
Its not a huge job to cut them myself, but if its not too much to get them water cut, I might go that route to save the job and get a neater finish (plus I guess that there will be a small saving in the unit cost of their steel stock that would off-set their price for the job a little bit).
Just had a very good job done by this company http://www.sussexstone.co.uk/ Based in East Sussex not far from Heathfield.
They cut cailiper mounting brackets as well as other bits and pieces. Just had to supply a DXF file with drawings, very helpful people
these guys were really helpful and well priced
http://www.h2ocreations.co.uk/
