does any know the correct measurements for the mx5 rear lower wishbones, I have the Haynes manual and also the mx5 additional booklet but it doesn't give correct sizes or angles. can any1 please help?? many thanks Ron.
http://www.roadster-builders.co.uk/forum/download/file.php?id=111
heres a link to the saturn plans theres a bit about wishbones, mine uses a talon diff setup so is different using standard bottom arms on the back
