Seamless tube for wishbones
craigdiver - 11/10/16 at 07:38 PM
Hi, having a bit of difficulty sourcing some 19mm & 25mm seamless tube for wishbones.
I have found a pipe supplier that does it but are asking questions such as wall thickness etc.
Does anyone in the know, know the spec of the tube needed? (The supplier says 19mm not common O/D, it would be something like 20.4mm?).
OR where to get it in Scotland?
Craig
craigdiver - 11/10/16 at 08:08 PM
Found an answer on the interweb from Talon Motorsport;
lower wishbone tubing is 25x2mm or 1"x14gauge CDS upper tube I use 19x2mm or 3/4x14gauge CDS both are mechanical grade Cold drawn seamless.
Is this purchased from a steel or pipe supplier?
daviep - 11/10/16 at 08:35 PM
I got mine from Hydraulic Power Services in Leven, it was 10+ years ago so no idea on grade actual grade, it was definitely CDS though.
Davie
hearbear - 11/10/16 at 10:03 PM
What about Alexander's in Stirling and Edinburgh Linky to site
ste - 11/10/16 at 10:09 PM
http://www.steelexpress.co.uk/structuralsteel/seamless-tubes.html
mark chandler - 12/10/16 at 06:01 AM
Lower wishbones, I used second hand Land Rover panhard rods, costs pennies as people through them away when the ball joints fail.
hicost blade - 12/10/16 at 08:23 AM
Seamless tube specifiaction:
CFS3 - Cold drawn mechanical tube
Can be bought from:
http://www.steeltubedirect.co.uk/
(Hub le Bas retail site...)
Dave
procomp - 12/10/16 at 01:03 PM
Hi
Don't use 3mm wall tube, you'll bend the chassis before the wishbone in an accident. 2mm / 14guage is most commonly used.
Cheers Matt
craigdiver - 12/10/16 at 09:14 PM
Thank you all
