I'd like to get my tintop into the air, car ramps seem like the easiest way to do it and would be high enough. But I want to get all four wheels
to the same height, and the front of the car is 'incompatible' with normal ramps (the ground clearance on the bumper is too low).
So I was thinking of simply using ramps as stands, lifting the car high enough on a jack and then getting the ramps under the wheels. Seems like a
reasonable plan, and it would allow me to put them under all four wheels (two at a time).
Then I thought do I need ramps at all? Could I weld something together that could hold the car up a similar height (about a foot or so).
It would be used with a 3 ton jack that can lift 520mm, so I can certainly lift it high enough to put something under the wheels, even with suspension
droop.
Anyone got any suggestions, ideas, etc?
Big blocks of wood, far more versatile than a purpose made stand, you can stick them in any where and stuff won't slide on the like it does when metal on metal. I've got loads of different sizes in sets, the biggest are 450mm x 450mm x 600mm
Like this ?
http://www.carlift-ramp-mr1.com
Or a shorter version of this maybe ?
www.hamercarlift.com
I have four big axle stands from Machine Mart and a big trolley jack. I can get my Transit 2' off the ground with no problems!!
Meh...2 long pieces of wood that you drive the car on first to raise it to the right height for the lift to work...maybe with the middle bit (where the lift arms go) being removable... simple and effective..
Ah..misread...thought you wanted to use something like a lift to raise the car... ramp extensions might work for you.. (either make or buy) then just
lift the rear end onto axle stands or another set of ramps using a trolley jack....
https://www.machinemart.co.uk/p/car-ramp-extensions/?da=1&TC=GS-051720001&gclid=Cj0KEQjwk-jGBRCbxoPLld_bp-IBEiQAgJaftbalcrGPHezSY8tGB4l5ZEJVL4
40tsRLQ-5F5eQYvLEaAsYT8P8HAQ
[Edited on 28/3/17 by stevebubs]
Another solution (similar to the MR1 above) http://www.locostbuilders.co.uk/forum/8/viewthread.php?tid=105193#pid877169
You could try 8 breeze/engineering blocks, laid on their side stacked 2 high, or railway sleepers cut up to give big blocks to stand all 4 wheels on. Obviously ensure handbrake is on and in gear so car does not roll off.
Originally posted by Andybarbet
Like this ?
I made these that fit under the body or the wheels and lift to 500mm:-
Paul G
And with a car on:-
Or a more interesting car:-
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=208167
Paul G
And with a car on:-
tbh if it's all four wheels I just use large concrete blocks stacked 2 -3 high with wood spacers protecting the car, primitive but doesn't
break, snap or tip over either. If it's just 2 wheels I'll just drive up double height ramps.
Want to build a pit some time in the garage when there isn't a car in the way...
Trolley jack and axle stands does it for me. Had most cars I've owned on them without an issue. I do have small strips of wood between the top of the stands and the car to protect the underside of the car.
I used spare wheels to get mine at a reasonable height, see picture on left, stable and cheap, keeps spare wheel out of the way. I used a trolley jack to get them to that height, used a scissor jack to get the trolley jack underneath, must get myself a low profile jack.
