Is there a resource here in the UK where I can send a drawing and they can knock out some parts?
What I'm after is suspension brackets in thick steel. Maybe 3/8" thick with 3/4" holes. 16 of these would do me to 4 link my front
axle.
Thanks,
[Edited on 4/8/17 by coozer]
I have used Lasermaster in cornwall, send them a dxf/dwg and they will send through a quote. I have had aluminium parts upto 10mm and had a steel
exhaust flange made up as well. Good service.
i think they will take hand drawn plans and then digitise them for you worth a call/email.
[Edited on 4/8/17 by Ugg10]
I've got Yorkshire profiles on my estate in Hessay but they tend to be quite expensive so I've started using Quality Components in Pontefract who are very competitive.
I use Laserjet in Plymouth and their sister company, Waterjet for 15mm thick aluminium starter brackets.
Mike
What I'm after is suspension brackets in thick steel. Maybe 3/8" thick with 3/4" holes. 16 of these would do me to 4 link my front axle.
Thanks,
