Where can I get some brackets cut? Need them pretty accurate, do I want CNC, water or laser cut? 4-5mm mild steel
Thanks in advance
I follow a lad on Facebook called Kinzy Fabrication, he’s just starting up, he has the means to make stuff.
https://en-gb.facebook.com/pages/category/Metal-Fabricator/Kinzy-Fabrications-1719116751634375/
[Edited on 17/6/19 by T66]
I have used these guys a bunch of times from making a simple wheel drilling template to cutting an engine adapter. Custom sizes based on their
"easy order" are ridiculously cheap! https://www.lasermaster.co.uk/
Laser cut from your description.
[Edited on 18/6/19 by miskit]
Thanks guys, that's great, I'll follow up on both :-)
