Hello,
Just have a question, in the UK do you have to demonstrate engineering for self made components such as control arms when you present your vehicle for
registration?
ie FEA reports, physical testing reports
In AU we have to demonstrate to the certifying engineer that self made components meet a certain level, and was just wondering what is the process in
the UK?
The answer is NO
However cars built post 1999 have/had to go through an inspection called SVA/IVA and if the tester saw some dodgy welding or poorly construction, the
car would probably fail
steve
No chance, testing in service, then moaned about on here when the wheels fall off...
Even aftermarket OEM parts have no paperwork with them so could be make from old fridges and Chernobyl for all we know.
Saying that I've had original suspension parts on tin tops fitted by the manufacturer snap right off at the welds so there's no winning
Full certification and testing, that's why airplanes are so expensive.
Not required. Plenty of dangerously designed aftermarket parts out there.
I once see an Iva/sva inspector say to a builder “your welding is poo but there is plenty of it so it probably won’t fall of”
Very interesting.
Thanks guys
In Victoria (Australia) all suspension components have to be deemed fit for purpose.
For made components they must be either physically tested or proven by FEA / hand calcs.
The load case is at the contact patch,
- bump loads: 4g vertical;
- rut loads: 1g vertical combined with 0.6g lateral; and
- skid loads: 2g vertical combined with 1.2g skid (longitudinal).
- overturning loads: 2g vertical combined with 2.5g overturning
tbh those loads seem quite low
So when you buy, say a replacement wishbone for your car it comes with all this certification??? here your doing well if it's in a bag, the sign
of quality...
So when you buy, say a replacement wishbone for your car it comes with all this certification??? here your doing well if it's in a bag, the sign of
quality...
nope never seen once any testing cert for an aftermarket part, best I've seen is a bag and a bar code, as for stuff made in China hmm
