Hi, Using the lock down time I'm going my 6 point seat belts.
Does anyone have pictures of the crotch / 5 &6 mounting points?
As I test I bolted them to the 3 & 4 mounts which I've read a number of people have done. Sort of works but I'd like to do it properly
while I can. I have an expanding foam seat.
I could place two mounts at the side of the chassis approx 20 degrees behind my crotch but that instinctively seems wrong. The mountings seem very
wide apart and would put the seat belt bracket in a bending instead of pulling motion.
Take a look at these - they tell you exactly what's safe or not. Personally I mounted them into the floor under the seat, but the second link
does say "This is achieved by sitting on the anti-submarining straps, routing them rearwards and attaching them in the region near or on the lap
belt anchorages." So maybe that's OK?
https://www.schrothracing.com/docs/Competition_Instructions.pdf
https://www.tillett.co.uk/shop/documents/downloads/seat-belt-fitting-information-2012.pdf
I've seen these, the problem is they reference having a seat. I've made my own from 2 part foam. It's damned comfy but has zero
strength. It's the same approach to a seat single seat racers and 750mc locost formula use.
I'm wondering if I mount on the chassis at the rear and sit on the crutch strap -but that seems wrong
