Hi,
I heard to use Sikaflex to join alu panels to chassis before to rivet them, but wich one?
Sikaflex 117? Sikapower 4720 with 20 times more strenght to add torsional rigidity? Others?
Many thanks in advace for any tips.
There will be a range of recommendations on here and some useful old discussion threads.
A common suggestion is Sikaflex 221: https://www.merlinmotorsport.co.uk/p/black-sikaflex-221-polyurethane-adhesive-sealant-pur-bk (manufacturer’s data
sheet: https://gbr.sika.com/dms/getdocument.get/8445dc23-8053-4492-b52c-9409a50064cb/sikaflex-221.pdf )
Some previous threads on the topic (there may be more): http://www.locostbuilders.co.uk/viewthread.php?tid=36074
https://www.locostbuilders.co.uk/viewthread.php?tid=207985
One from Locost USA website with some interesting thoughts: https://www.locostusa.com/forums/viewtopic.php?f=23&t=11916
Mike
[Edited on 31/10/21 by Mike Wood]
If you've got a Wurth shop near you (there seems to be one in Bergamo) then this stuff is pretty good too:
https://eshop.wurth.co.uk/Product-categories/Bond-and-Seal-structural-adhesive/31083005041106.cyid/3108.cgid/en/GB/GBP/
and as a bonus its only £7.30 each inc VAT (I have to assume its a similar price where you are too)
its the stuff that Dax used and loads of other vehicles too (inc holding the panels on train carriages)
[Edited on 31/10/2021 by mcerd1]
Any pu glue type sealers I glue new panels on buses and we use tiger pu but as above there are lots of different makes make sure it has pu on the
tube
Jacko
Ps put gloves on don’t get it on your hands if possible to smooth it use soppy water
[Edited on 31/10/21 by jacko]
Thanks to all for your helpfull tips. I think the best solution could be the PU from Wurt that I can buy next to my home
Always strikes me that bonding panels to a "painted" chassis must be largely down to how well the paint is adhered to the chassis. The panel adhesive could be stuck massively well to the paint, but the paint may simply "peel" off the chassis!
^^ I'm sure the OE manufacturers have to take that into account somehow...
but this is why for most car like ours its recommended to strip back and key the contact surfaces
Having recently tried to strip off a badly painted inlet plenum I can say that most paint will not strip off in the manner that wall paper would, powder coating may strip off partially but this is usually due to corrosion under the powder coat and if bare metal was corroded prior to gluing that would definitely cause issues, so make sure your chassis is prepared properly for bonding on panels.
Really in this case it's the rivets that are limiting how much strength your getting not the glue. For the glue to contribute the rivets would
have to be deforming which they won't unless you crash, in which case stronger glue might be nice
If you were considering crash worthiness then maybe look at some of the newer structural adhesives used on most modern cars rather than windscreen
stuff as they are amazingly strong and sometimes the metal fails before the glue. However most of these I've looked at do require a very tight
panel fit and super clean surfaces, which rules out most of my applications...
^^^ keying the bond area is still a good idea
you only need to remove the paint / coating up the centre of the where the PU is going to go (I needed a flap wheel as my powder coat was really well
stuck on ) the idea being that the adhesive should squish out a little and overlap with the remaining powdercoat / paint to seal it all up - no
touch up required if your careful
also keying the alloy or GRP panels - again just rough them up in the area where the glue will be only (I test fitted the panels then scribed lines
round the edges of the tubes to keep it neat - then just be careful with the course emery paper)
this way the PU is probably doing most of the actual work - the rivets are probably just clamping it while the adhesive cures (but they do also
provide a good secondary mechanical fixing just encase)
also if you are comparing different PU adhesives you'll see that some are much stiffer when cured than others:
the Wurth bond & seal stuff I linked to above is great for high strength and pretty stiff too - its similar properties to Sikaflex221
something like tiger seal is much softer and weaker, but good for bonding in brittle things like glass (also harder to find any proper data on as its
more of a consumer product than the others)
don't take that to mean I don't also have rivets in mine though.... 've just got a few
compulsory floor panel pic
my new favourite tool
floor on !
[Edited on 1/11/2021 by mcerd1]
also I should add that I treated myself to a few 'skin pins' and a big (cheap) bag of cleco's too - they make it so much easier
when your pre-drilling the panels - as soon as you have a couple of holes done and pinned (say one each end) the panel can't go anywhere - no
alignment issues ever again
this way its dead easy to pre-drill everything and scribe the edge of the tubes on the panels - then take the pins out knowing it will all go back
perfectly once its stripped back, the glue is on and you start the rivets...
like these but you can probably shop around for better deals, but these seem to be a good price just now:
https://www.lasaero.com/products/article/O0273HUC5
https://www.lasaero.com/products/article/X01A0QWGL
then next step if your feeling lazy like me is some kind of powered rivet gun...
PU glue will be good also to glue big heads fixing to the fiberglass of body or rear of the alu dashboard or is it necessary to use e more specific glue, like two components resins?
