Like alot of people I'm over 6 ft. (6'3" and 230 lb)
I cannot fit into a Lotus 7, and am hesitant to start construction on a Locost configured to Ron Champions specs as I have heard conflicting reports
as to whether I would fit. Has anyone built a Locost to the dimension of the Caterham SV or the other larger Caterhams. If so, are the plans
different, or is the Ron Champion designed modified? I am planning to use an MGB running gear and live in Toronto, Canada. Thanks for the help.
Toronto, thats where I'm gonna be tomorrow, on the first let of a 3 week snowboarding holiday
Have you looked into the mcsorley plans? There are designs for larger locosts on there www.mcsorley.net
I don't know how these compare with the caterham SV etc, but there's a +4 (width) and a +442 (4 inches wider, 4 inches longer and 2 inches
higher)
Hope this helps
Mark
You should check out McSorley's website. http://www.mcsorley.net/
He has plans (under drawings) for a book chassis with 4 inches add to width and length and 2 inches to hieght. Its the same chassis i'm building
(I have to my engine is 27 inches high!).
Good to see another Canadian here, I think 7's are gonna be popular here soon.
/edit damn, i'm too slow this morning!
[Edited on 5/3/05 by Spottty]
MGB axle will cause problems for building a wider car it is narrow -- slightly narrower than the book Escort axle.
dont know why you cant fit in a locost,i have a MNR vortx and im 6ft 4inch and 17 stone i fit no probs
Don't forget that the Locost chassis is wider than the Caterham/Locost in the passenger compartment - it's far closer to the Westfield.
I can't drive a Caterham - the pedals are too close together for my big feet!!
I know its not strictly locost but Tiger Racing now do what is generally reffered to as a FatCat that is wider in the beam. I bought just the chassis and body pack as i wanted to do everything else myself. It uses sierra mechanicals, there must be a sierra equiv in Canada i would think that uses the same or similar running gear? they also do a left hand version.
I agree...
Either Mc Sorley.
Or a Luego Viento.
My Son is 6ft 5", and I am 5ft 10". No Problems.
Plus it takes a nice mMMMMM V8, Its spec'd for most V8's, especially the small block version.
Luego Sportscars
Hmmm Why did I put the link on... they sponsor this site!
