Mc sorely +4
omega 24 v6 - 21/3/05 at 08:19 PM
Is the +4 only wider from the scuttle area back and if so are there any disadvantages to leaving the front track as std and using std bones etc.
Should have said i want to use a 52" axle.
[Edited on 21/3/05 by omega 24 v6]
Triton - 21/3/05 at 08:22 PM
Body work will be the problem, GTS are now doing +4" bodywork to suit the Mc sorley so make it as per the drawings....makes life easier.
omega 24 v6 - 21/3/05 at 08:24 PM
surely only the scuttle is the problem if you are making your own side panels and bonnet.
phelpsa - 21/3/05 at 08:28 PM
And nosecone
omega 24 v6 - 21/3/05 at 08:31 PM
not if its only wider from the scuttle back. I am having real probs here trying to decide what to go for a std book a +4 or a +442. At the moment a xflow would be my choice but what if after its completed i wnt a 16v xe.
Ben_Copeland - 21/3/05 at 08:56 PM
You can get either engine in a book chassis... so i wouldn't worry too much about choosing between the 2
omega 24 v6 - 21/3/05 at 09:00 PM
What about width for seats Ben.
Ben_Copeland - 21/3/05 at 09:07 PM
Depends how fat your arse is
omega 24 v6 - 21/3/05 at 09:15 PM
36 inch waist and slightly fatter arse but it fits in a kart seat LOL just. I was only asking to be considerate to the missus but on a serious note how wide is it from the tunnel to the side how big a choice of seats are there (getting a bit out of this section now )
Triton - 21/3/05 at 10:12 PM
If going wider, stick to adding 4" down the middle and not just in the cockpit
craig1410 - 22/3/05 at 12:51 PM
Look at the McSorley website for details of the differences between the 7+4 and the 7+442. I am building the 7+4 and it is simply a book chassis with an extra 4" added right down the full length of the chassis. The 7+442 is designed to use a standard nosecone and you'd be best to read Jim McSorley's website for exact details of this.
Craig.
jestre - 23/3/05 at 01:44 AM
Offtopic, but, I like your "building" line
My wife isn't too enthused either.
omega 24 v6 - 23/3/05 at 08:42 PM
Cheers jestre She ain't keen but its gonna happen. Its just a matter of time. I have not got a lot of room and 2 cars already one of them a v6 omega 1998 with a gen 40000 miles that is minted trouble is i won't get near what i reckon its worth so untill it dies i'll have to 2wait.
scuzzer - 24/3/05 at 08:34 AM
I, personally, am seriously considering a custom chassis: +4 width +2 length. The 4" increase in width will be straight down the center. The +2" in length will be split: one inch added to the engine bay and one inch added to the cockpit. I plan on running extra rails for side impact protection.
dozracing - 24/3/05 at 06:02 PM
The GTS W7DE is +4 wider down the whole length of the chassis.
We are prepared to make custom mods to this if required, ie, make the cockpit longer etc.
The bodywork will be available as a full 10 piece kit, but obviously from that you can choose to have only the scuttle and nose if you wish.
Kind regards,
Darren
[Edited on 1/4/05 by dozracing]
omega 24 v6 - 24/3/05 at 08:10 PM
TRhanks for all the input folks the only thing that does concern me about a
+4 would be the availability of a windscreen which will prob be a must for the missus.
clbarclay - 24/3/05 at 08:30 PM
yer missus doesn't need a windscreen, just tell her head scarfs are coming back into fashion.
omega 24 v6 - 24/3/05 at 08:49 PM
Its to stop her making a whistling noise out of her arse as she trys hard to close her mouth after screaming.
clbarclay - 24/3/05 at 09:00 PM
No you've got it the wrong way round, in the mouth it moufles the screams and stops the whisling noise.
omega 24 v6 - 24/3/05 at 09:03 PM
LOL
clbarclay - 24/3/05 at 09:13 PM
The other solution is to get her to crouch in the foot well and fit a tonneau cover over the top.
dozracing - 1/4/05 at 04:34 AM
I can do +4" wider windscreens and the range of other parts to suit.
Kind regards,
Darren
omega 24 v6 - 1/4/05 at 08:04 PM
Nice to know that Darren for the future.
James - 2/4/05 at 11:12 PM
Darren,
Too much self abuse means I can't seen them on your site- how much is a windscreen?
James
dozracing - 6/4/05 at 12:57 PM
Glass is £55 cut to size.
Frame is £28, and uprights and £22
Kind regards,
Darren
