Hi Guys
Can any of you guys help me check a few dimensions for my bent chassis that I am rebuilding. I need to know what the dimensions are in between the two
crosstubes in the engine bay the first dimension is from the crosstube at the bottom of the footwell to the cross tube just in front of the rack. I
also need the same dimension but on the upper half of the chassis.
Thanks Carl
