SVA build information
merlin - 13/12/01 at 06:15 PM
Does anyone have the correct height from the ground to the top of the seat belt anchorages? I am fitting 4 point harnesses and the book doesn't give a height but I know there is a minimum for the SVA.
Same question goes for headlights, what is the maximum/minimum height?
richlhart - 14/12/01 at 10:46 PM
I'm not too sure about the seatbelts. However the "Car Builder's Manual" states that......
"The lowest point of the headlight must not be less than 500mm........highest point must not be more than 1200mm"
mad-butcher - 8/4/02 at 08:16 PM
they place a block on the seat where it joins the back the block comes forward 136mm and is 53mm high the minimum reference height for the top mount above this point is 450mm generaly it means most locosts need the back rail mount raising about an inch
tony
