Please please please could someone confirm for me that 'C' as listed in the book is 10mm too short as has been suggested here.
Since reading that, I've cut a piece 10mm longer and have to say that it doesn't fit aswell as the shorter 'C' did. I'm quite tempted to stick to the
shorter one but I'm worried about the effect on the suspension brackets.
I really need to start welding tomorrow so would like to know one way or the other!
If no'ones got it worked out, could someone with a built chassis measure their's for me.
Thanks in advance,
James
Yo James just looked at my colouring book ,the tubes taper there ,so if you cut to the long length on 1 side and the short length the other it should
fit hopefully?
Yes, C is too short by about 10mm.
Also found that G1 G2 are too short if you do the 5" bit, and the 'L' Uprights by 5mm.
Also if you do the maths on the J's they are too long. . .
For a 2nd edition of the book to contain all these inaccuacies is not good. . .
Hi JohnFol,
How did you calculate 'C' as being too short.
Sorry to question you but I've now cut all the lengths for the bottom rails and having laid them out on the jig it all fits together pretty well with
'C' as per the book. I've cut an additional 'C' with 10mm extra and fitting this pushes all the rest of the joints out.
So, if the extra 10mm is needed then I've somehow cocked up a load of other rails and they'll all need adjusting/re-cutting. Which is probably why
you'll understand me double checking with you!
How did you conclude 'C' was wrong?
Thanks,
James
I'll dig out the book tonight as I don't have fgures to hand. . .
Anyone got a scan of the page?
A good way to confirm the length of C is to lay it all out and then measure the angle between D and B2. The angle should be exactly 80 degrees. At least with angles we don't need to worry about inches vs. mm! ;-)
PS I did dig out the book and a quick look suggests C is listed correctly. What puzzles me is several other people have also said C is 10mm too short .. . wierd!
Have you placed 'C' on the correct side of the line drawn on the layout board? If you place the front of C on the rear side of the line, it will
appear to be 10mm too short.
-Jim M.
I am sure I placed it on the correct side of the line. If it were on the rear I would have squared off ends.
(all from memory I'm afraid)
PS I thought I hit reply whilst in a different forum / . . .. .
Yep I'm right. I go to
http://www.locostbuilders.co.uk/xmb/viewthread.php?tid=437
read jbmcsorley's last comment and hit reply . I then get the screen I am typing into now, but the last comment is from James. . .
Did you draw the line on the correct side of the line?
I'm being silly... but my point is this; head out to the shop with a tape measure and
confirm that you have a 21.5" (546mm) spread between the closest sides of B2 and C.
Is it just that the book is wrong? I measure 'C' in the book design at 823mm on it's longest face and the cut angle should be exactly 10 degrees (I
know, cutting exact angles is nearly impossible... but a steel protractor is one of my favorite tools).
-Jim M.
Is it just that the book is wrong? I measure 'C' in the book design at 823mm on it's longest face and the cut angle should be exactly 10 degrees (I know, cutting exact angles is nearly impossible... but a steel protractor is one of my favorite tools).
-Jim M.
ALT 248 °°°° Yep ALT 248
When I was working out the angles to cut I looked at the plan and calculated the angle from the dimensions. I worked out 9.5°, which I thought at the
time was a bit strange and wondered why he hadn't used 10° but that was before I understood the truth and became bitter and twisted.
PS so how did you get the 50° angle on K1? That was one I boobed the first time.
*What's a degree sign in ASCII?
Me too. °
quote:Have to admit I'm a bit annoyed that there's this many inaccuracies in a 2nd edition- I really don't think it it'd be that hard for Heynes to make an amendment- even if it's only as much as a new cutting list on an extra sheet slipped inside the cover.
When I was working out the angles to cut I looked at the plan and calculated the angle from the dimensions. I worked out 9.5°, which I thought at the time was a bit strange and wondered why he hadn't used 10° but that was before I understood the truth and became bitter and twisted.
That's what I tried but I still ended up with 40° but upside down and not 50° as I had initially thought. Hmmmm. Really need to put it in at right
angles to the clamp to get 50 I think. Same goes for TR1-6 which have acute angles too.
Dunc.
Oh, ok, weird! Interesting problem- I'll think about it a bit because I'm sure it muct be possible!
To be honest though, with the time I've got available (only 6 hours per week) in the college workshop and my deadline of having the chassis done by
the end of term I think I'll just cut by hand and think about how to do it on the saw later!
James
