OK , i have sold my old Mk wishbones so im looking ato buy some new "indy" ones at stoneleigh, anyone know if they will go straight on the
book chassis ?
I think the mounting points are slightley wider apart, is this correct ?
also, does anyone know how wide the track is with these wishbones ?
cheers
Glenn
Hello...
MK Indy wishbones wont go onto a book chassis. His Indy chassis is his own design and uses different size brackets/bushes and what not as well as
different mounting positions.
I dont know if there are any suppliers of wishbones suitable for sierra width that will bolt onto a book chassis (luego or lolocost maybe - dunno).
You may have to make them yourself =)
LIam
Oh well, i guess i'll be saving money but geting a few more burns
anyone have the dimensions for the sierra upright ? so i can work out the wishbone lengt.
can't remember where this pic came from
[Edited on 2/5/2003 by Viper]
and it hasnt come up....
have a look in my archive...under sierra upright
one good rule
dont commit to making anything for something you dont have in your hand.
its a lot easier to measure the part and design around that then take a best guess.
I speak from experience! Also, the pivot point isnt at the ends of the upright, its in the joints, so you really need the upright and top and botom
joints fitted to properly understand the geometry.
take a look on TOL in the files area for summat called the suspension helper.
its a simple program that lets you play with dimensions and see the effects on wheel movement.
atb
steve
its ok stephen, i wont be making that mistake, i just wanted to get an idea of the sizes involved. Its helpful to get a few jots down on paper.
