Hi all, im new here. Hope you can all help me and i will try and help you.
Right then, im building the 'book' locost for 250 quid(250 is already out of the window). I had most of the metal cut to make the standard
size chassis with intention of pinto power. I was considering making the chassis bigger to have more room... I had a very good opertunity of Ford V8
running gear which i have taken so now my locost becomes a bit of a mad task.
My questions to you are:-
Has anyone made there chassis bigger? if so was it hard to do.. I have worked out most of the measurements..
Has anyone made a chassis and put a V8 in it??
Cheers hope you can help..
Luego do a pre-built 'bigger' chassis called a Viento. The other advantage is it runs the Sierra back end with wishbones so no need to
source an escort axle.
Chris
Right then, im building the 'book' locost for 250 quid(250 is already out of the window). I had most of the metal cut to make the standard size chassis with intention of pinto power. I was considering making the chassis bigger to have more room... I had a very good opertunity of Ford V8 running gear which i have taken so now my locost becomes a bit of a mad task.
Cheers hope you can help..![]()
) has accurate standard chassis plans and also plans for a larger chassis. Hi, thanks for the replies. I looked into the Leugo viento but they wont sell just the chassis..
