hi there. i got a luego locost with the locost sierra type front bones, problem is i would like wider ones as the rear axle is wider than the front,
im not using the normal escort axle, i am using a toyota ae86 type axle which is wider than the escort.
what i would like to know, are the velocity wishbones wider than locost ones???
can anyone help?
thanks
rob
Dont think so. Most 7's are wider at the rear...
Velocity xt front upper and lower wishbones are longer than standard locost items by about 2-3 inches.
