Hi,
I am in the planning stages of building a spaceframe chassis for a road car
It will have zetec power and Mt75 gearbox
independant front suspenion with 5 link rear
The shell will be steel for the roof and rear quarters and rear panel with fibreglass doors, bootlid and flip front.
7 x 13 wheels with 175/50/13 tyres
I was just wondering if the locost chassis tube sizes would be man enough??
Luds
Yep, will be plenty strong enough
The strength of a chassis is dependant on the design as well as the material. For a properly triangulated spaceframe the tubes used for a locost
chassis are ample, even with some serious power.
Thanks for the advice David, Will get designing now then. It should be a strong chassis with the extra strength of a full rollcage.
Luds
And I'd not use steel for any panels - far too heavy.
Ali will do fine is the chassis is done right.
Pat...
