master cylinders
joolsmi16 - 13/12/06 at 05:58 PM
Hi all, do master cylinders on a floor mounted pedal box need to sit in side the chassis rails?
Currently having a move around on the front of my chassis and found that one of the brake M/C now overhangs the bottom rail, so now sits between the bottom rail and edge of the bottom cockpit rail.
Hope thats clear-ish
kb58 - 13/12/06 at 06:08 PM
They need to be someplace that's really strong, inside or outside. There's a lot of force trying to rotate them when you're hard on the brakes. It could easily be 1000lbs with the pedal leverage. Regardless where they are, put them near a tube if you can, or at least box it in with 1/8" plate.
[Edited on 12/13/06 by kb58]
zetec7 - 13/12/06 at 06:19 PM
If it helps, I'm raising mine 1" using a piece of 1/8" plate. I've been advised that having something for your heel to rest against on the floor is a very good idea to help against fatigue, so the 1/8" plate will be welded to the top of the horizontal tube at the bottom of the firewall, and those on either side, and will come back a few inches, where it will be bent down to meet the floor (thus forming a heel rest). Should make a very strong mount for the pedals. I'm going to weld captured nuts on the underside of the plate to bolt the pedals down. Hope this description isn't too confusing...
joolsmi16 - 13/12/06 at 07:04 PM
Hi chaps I mean the position of the master cylinder the engine side of the bulk head.
The M/Cs are secured to a metal floor mount box just concerned if there is a rule under SVA that the M/C must be enclosed within the chassis rails?Image deleted by owner
kb58 - 13/12/06 at 07:29 PM
In my opinion, that's too flimsy. The panel those mount to should be 1/8", gusseted to the main tube below. Better yet would be adding a second parallel tube above the master's, and have the plate run between them.
Remember that whatever flex you get on that mount, will get amplified by your pedal ratio. In other words. if the cylinder bends the panel 1/8", you are introducing 1/8 * 6 (or so) = 3/4" mushy pedal feel.
oliwb - 13/12/06 at 08:01 PM
Why've you taken out the outside bottom rail? I imagine that will weaken to the extent of endangering the chassis! Also depending on how your bodywork fits on don't think MC's would pass like that as they'd be exposed so radius's etc would be a challenge.....I would certainly put back that outside rail and maybe gusset a bit as others have mentioned....better to over-engineer than under - especially when it comes to brakes! Oli.
joolsmi16 - 13/12/06 at 08:03 PM
I am not concerned about the strength of the firewall because thats not load bearing as the M/C are mounted to a steel pedal box inside the footwell.
I am curious to see if Mr SVA has any issues with the M/C being outside the confinement of the chassis rails, with the two rails highlighted in white removed??
joolsmi16 - 13/12/06 at 08:11 PM
Sorry I should of said that its not on a locost build I have'nt got any pics of my build to hand.
Mines a mid engine build "full bodied"
