I'm sure you all know if you look deep down inside yourselves
which engine are you planning to use?
maybe some slightly more direct questions....
what engine?
what gearbox?
tom
dude your gonna have to type a bit more in the BIG text box!
[Edited on 1/5/07 by zxrlocost]
I am fiting a Toyota 4AGE 20v with the w55 box and want to get the whole thing further back 150mm so I need to cut out the section marked "Q" in the book chassis how should I do this?
thats quite an important tube, why do you need the engine so far back?]
you would have to brace P to make up for it. Work out what has to go, fit the engine, and see what you can add to make up for it.
[Edited on 1/5/07 by JoelP]
what about making the middle of Q into an X between the tops of the H tubes and P?
you still don't get a straight load path, as you would with Q, but from a 'looking at it' point of view, it would appear to work.
tom
Can i ask if its such an important tube, that Mac #1 see fit to split is right in the middle and effectively have two at the ends of each footwell ?
