The book says that G1 and G2 can be moved to accommodate the engine fitment. However, I'm going to build my chassis first and get a donor later. Does someone have the measurements from their car fitted with this engine? I don't want to weld it up, then grind it off and do it again later.
Vince,
I did exactly what you are doing, but numbnuts didn't ask this question first. I welded the Gees as per book and the fitted the Pinto - and then
had to cut out a section. If you put the N/S G 1" outboard, you will be OK The picture shows it all.
I am sure you will be able to help me out soon, I am just about to embark on stripping out my loom
Hi Guys. Thanks for that. So basically I will put G1 one inch towards the outside of the car.
No problem. Great this computer.
If you do have a problem with the wiring then please give me a shout on the mobile 07736 202101 I'll be only too happy to assist where I can.
why not leave those two out till you have the doner engine, you may even change engine choice by then......
just a thought.
I put mine far enough apart to drop the engine out downwards if necessary. If you are making your own engine mounts it's not too critical.
yours, Pete.
Good thoughts guys. Making my own engine mounts. Yeah why not.
Steel arives tomorrow. Can't wait.
yours, Pete.
